I have 52-11 on my triple, can someone work out what speed someone who is a lot younger and fitter than I am attain because I feel sure I am never gonna find out 🙂
Sure, in miles per hour = 0.0373 times wheel/tyre circumference (in metres) times cadence (rpm) times [number of teeth on large chainring] divided by [number of teeth on smallest sprocket].can someone work out what speed
Put the tyre size in and it'll 'tell' you the estimated overall wheel circumference. |
Is that calculation relative to a 42t or 48t ch/ring?
Just to be clear I am stickiing with my 12-28t
To give you a little more insight to speeds...
In the world of time trialling a 20 mph ride, either 10 miles or 25 miles, will be achieved by probably 99% of riders by the end of their first season.
But those achieving a 25mph ride in their first season is a very very low %. In my case, in over 500 timetrials, spanning over 50 years have only ever beaten 25 mph once. But at the tender age of 72, can still do a 10 mile TT at 20mph.
So you can see aspirations to increase speed from 20 to 25mph, will require gigantic effort.
That's a 120"+ gear.
A young Chis Boardman, riding a 110" fixed gear returned comp record for 25 miles of 45 mins 57 secs. If only he'd listened to advice and ridden a 120"gear, he would have got under 40 minutes!
Yep, pretty much spot on. I average about 15 usually. Just like to be out in the fresh air enjoying the freedomMaybe the OP just has a few short sections he's spinning out on and wants a couple more mph on, rather than trying to average 25 over mile after mile on a time trial. As a relative n00b myself with a flat bar hybrid, who's only just getting my head around gear ratios, I relate to this.
If that's your motivation than you should make it clear in the original post. You were attempting to back it up with some sort of mechanical/mathematical reasoning that simply isn't there. People on here haven't questioned your desire but said motivation - primarily because they have a far greater understanding of the subject and recognised your motives as questionable, to say the least.I just want to lose the triple with a twin.
I want to go faster. I now have a 12-28 7sp cassette new shimano IG51 116 links. Has a triple crank T42-34- ? (never used it no interest) Hybrid I would really like just a 2x chainring set with either a T48 or T46.
there is slight play in the bb so thought would be a good time to replace the chain set that
I'm not that happy with atst. . . . . it's the gearing that's the main problem
All good. Well just get on with it then.I just want to lose the triple with a twin. All hail the naysayers trying to shoot you down in flames, how dare a n00b question their reasoning.
To get that extra margin so you don't spin out with the wind behind you, I'd go to a compact (50-34). Your FD (triple type) will achieve shifting satisfactorily and as @C R has said your LH thumb lever will pull the cable.
Likely the new chainset will need a shorter BB spindle (this one needs a 110mm) to get the chainline right (and ensure the FD cage can reach). You will need a new chain as your large/large is 8 teeth more.
Moving from a 42t to a 50t ring would get you 19% more speed at the same/your highest achievable cadence.
Good point, mitigated by the fact that the OP "wants to lose the triple with a twin (sic)" so the chainstay won't be in the way of the 50t ring - possibly the 34t (of a compact). The current middle ring (32t?) is about 3mm further out than an inner of a compact (34t). Checking the clearance now will give an idea whether it'd be an issue. A chainring radius increases by 2mm for each extra tooth (12.7/2pi).As this is an MTB orientated bike, there is a good chance it will be impossible to fit a 50t chainring due to there not being enough clearance between the chainring and the chainstay.
