Chainring Replacement Instead of Crankset/Chainset Replacement
  • Thread starter Deleted member 35268
  • Start date
I was looking to replace a Triple 9 speed crankset/chainset as the centre 39 tooth ring is very worn. Its a Shimano Sora unit.
A complete replacement is going to fetch at least £70.00 so I have decided just to swap out the middle ring - for just a tenner.
I've done this before and it is pretty easy so long as you can identify the right part with correct BCP, Model number, number of arms etc.
Hopefully my winter bike will be back in action by the weekend
Paulus
Barnet,
It's the cheapest option if the other rings are ok.
You may find that you need a new chain as that may of worn and might slip on the new ring.
Ajax Bay
East Devon
The middle ring tends to get the greatest wear.
https://sheldonbrown.com/cribsheet-bcd.html
Spa Cycles ftw (£6) for a 38t/110mm BCD: https://www.spacycles.co.uk/m8b0s210p4819/SPA-CYCLES-Alloy-Chainrings-38T-28T
I'm guessing 5-bolt and 130mm BCD (but could be 110mm (!£15)).
Edit (agreeing with @gbb): You don't need to replace the chain or the cassette when you change a ring. Cassette sprockets last maybe 3 chains so 7000km: chainrings last 25,000+km. A worn chain will cause faster wear on a chain ring tooth than a chain within the +0.75% elongation 'limit', but much less than the wear on each sprocket tooth: cod-maths analysis available.
roubaixtuesday
self serving virtue signaller
gbb
Peterborough
Will do, and chain!
From experience, I'd buy and fit a chain ring and use it and see, At worst, measure the chain wear make a decision on that. If its nearly worn out, replace, if its OK, I'd probably run it if it were mine. Cassette, I wouldn't generally replace until it gave problems.
6 and 2 threes, I used to work with a guy who replaced all three every year. He was a year round commuter and the extra cost gave him some certainty and problem free running for the next year, plus it was still cheaper that his bus fares.
Glasgow
Thats the fella. Unfortunately I have broken a rule and replaced a black one with a silver one! Shock Horror
No worries: I just got my LBS to do the same as you, but they could not find a new chainring in stock to order, so they used (with my permission, of course) a black chainring from a donated bike.
The whole drivetrain is already black from the couple of weeks commute since it was fitted :whistle:
