I mentioned my current problem in the 'what have you fettled today' section but I think that was the wrong place so I'll try again here.. I have just replaced my 36t OEM Inner chainring with an FSA part but something us not quite right. They are both labelled as 10spd but the chain seems to slip on the new one. I have had a close look and it is as if the teeth don't protrude far enough through the chain links causing it to slip. The chain is also new but is a Shimano Tiagra chain not an FSA. The new ring appeared to be lighter in weight and I'm now wondering if it was possibly a bit thinner too. If so, then it was not noticeable enough to warrant the use of spacers IMO.. Would that make a difference to the way the chain meshes with the teeth on the ring? The finish of it was also more like what I'd expect of an outer ring than an inner (Gloss paint with branding etc..) but whether that makes any difference I honestly don't know.
Any ideas folks?
Any ideas folks?
