02GF74
I bought a lovely KMC gold chain off the bay and dithering whether to replace chain or not.
The bike chains are 1/2 inch which means that for 10 links, a new chain should measure 12.7 mm.
I measured it to be less than that, don't recall figure but could be 126.2 mm. Strange. I would have expected it to be 127 mm.
I am guessing that the chain is slightly short to exten life, i.e. it wears a bit so becomes the true 1/2 inch legnth then can wear a bit more past that.
I got numbers off the web a while back the length of 10 links on a new chain and the 1 % increase whcih is when the chin should be replaced, I cannot recall the first numebr but the latter is 127.6.
I have been using the 127.6 mm for quite a few years and can get at least 3 chains on same cassette prior to having to replace cassette.
Anyone wishes to comment on these numbers?
Thinking of getting one of these but if my method is osund, is it worht the £ 5?
The tool is far easier to use as it eliminated any guess work.
I don't suppose anyone has come acros a dimensioned drawing for this type of tool?
Over to you knowledgeable peeps.
