davidphilips
Phil Pip
- Onabike
The inclement last month on the busway has speeded up the wear nearly 2,000miles probably didn't help either
Last time I had this problem after replacing both the chain and cassette, it was a worn chainring causing the problem. Is it happening on every chainring?
You don't seem to have answered @Threevok 's question.I'll try it on those and see what happens.
LBS have adjusted grearing, cable tension etc., to no avail. He reckons it's a freehub issue,
I know... Surprising, and disappointing, if you know who my LBS are...
Outer chainring, looking more "peaky" than "shark finny"
Cassette
Question; can I change that outer ring without taking the crank out?
Thanks, I thought it might be possible if I slipped the chain onto a lower ring but just wanted to checkYes, maybe harder than removing crank but can be done in place just 5 alan bolts just make sure the bolts are fully tightened.
@Dec66
Q. can i replace a 12-27t cassette with a 12-28t? i've just fitted the chain for the current 12-27t so may have snookered myself?
