nmfeb70
- Tonypandy, Wales
Just count the links on the old chain if that was right. Chain needs to be able to survive, but never be used intentionally in big:big, once routed through rear mech (it'll be near straight) then just long enough to make a join, or when fitting new chain it's often easiest by missing the rear mech out but add a link (a pair). Get some quick links.Hi all, I've cut this chain too short and wonder if anyone can advise me on how many links I should put back in? I want to get it right as I only have a couple of pins left and they aren't cheap! Thanks.
I measured the chain to the old one but it was jumping all over the place. Another chain as suggested by @Juan Kog might be the best option.Just count the links on the old chain if that was right. Chain needs to be able to survive, but never be used intentionally in big:big, once routed through rear mech (it'll be near straight) then just long enough to make a join, or when fitting new chain it's often easiest by missing the rear mech out but add a link (a pair). Get some quick links.
I see from your other thread it’s 7/8 speed , so annoying but not to costly to replace . The chain you remove may fit another bike in the future. My workshop ( the velo cave ) is full of things that may be useful in the future .I measured the chain to the old one but it was jumping all over the place. Another chain as suggested by @Juan Kog might be the best option.
You only know if the old chain is "right" by checking it large/large: the rear mech cage should not point higher than 5 o'clock.Just count the links on the old chain if that was right. Chain needs to be able to survive, but never be used intentionally in big:big, once routed through rear mech (it'll be near straight) then just long enough to make a join, or when fitting new chain it's often easiest by missing the rear mech out but add a link (a pair). Get some quick links.
