- South Manchester
Ohhh 'internet wisdom', I like that.
Ohhh 'internet wisdom', I like that.![]()
Always been a disciple of not cross chaining; 'rule of threes' as I call it. However, it's surprising how common it is among cycling folk who you would maybe expect, by their mount and attire, should know better, but obviously appearance and kit has no correlation whatsoever to their understanding of care of the drivetrain - !
Saw a manny last summer who had some fancy MTB that had a single chainwheel and an 11 speed cassette. He insisted that chainline wasn't an issue - !![]()
Isn't the 11 (or 12) speed cassette the same depth as a 10 speed, and the chain narrower and more flexible, so the chainline effect less?Always been a disciple of not cross chaining; 'rule of threes' as I call it. However, it's surprising how common it is among cycling folk who you would maybe expect, by their mount and attire, should know better, but obviously appearance and kit has no correlation whatsoever to their understanding of care of the drivetrain - !
This.A scraping FD is actually a blessing because it warns you of you doing illegal stuff with the chain. Put it out of its pain and shift.
Point I was trying to make is that 1x set ups require cross chaining in top and bottom gears, or at least as much cross chaining as a large to large or small/small would be with a compact chainset. SRAM's Yaw design elegantly avoids cage/chain interference while keeping the cage reasonably narrow (for crisp chainring shifting).SRAM Yaw front dreailleur with wi-fli gearing - no rubbing when 'cross chaining'.
Just because it has LESS EFFECT doesn't mean it has NO EFFECT at all.Isn't the 11 (or 12) speed cassette the same depth as a 10 speed, and the chain narrower and more flexible, so the chainline effect less?
Very true. I didn't say NO effect. I'm suggesting that (perhaps) a 1 x 11 or 12 setup may suffer no increased ill effects from cross chaining than (say) a 2 x 9 or 10, given the flexibility of the 11/12 speed chain. Any one know? Yellow Saddle?Just because it has LESS EFFECT doesn't mean it has NO EFFECT at all.
I haven't done any measurements on 1 x systems but I think they will be better than 2 X systems. Reason being, that the single chainring can be placed exactly in the centreline for a perfect chainline in the middle sprocket at the rear, with 5 sprockets either side of it. Contrasted to a 2 x system the chainline falls between the two front sprockets, biasing the chainline upwards and downwards at the rear. In the extreme, a cross-chain would be worse than in an extreme in a 2 x system.Very true. I didn't say NO effect. I'm suggesting that (perhaps) a 1 x 11 or 12 setup may suffer no increased ill effects from cross chaining than (say) a 2 x 9 or 10, given the flexibility of the 11/12 speed chain. Any one know? Yellow Saddle?
On a 1x11 system you need to tolerate a 'cross-chain' angle of 2.6 degrees to use the largest and smallest sprockets (which of course one needs).I haven't done any measurements on 1 x systems but I think they will be better than 2 X systems. Reason being, that the single chainring can be placed exactly in the centreline for a perfect chainline in the middle sprocket at the rear, with 5 sprockets either side of it. Contrasted to a 2 x system the chainline falls between the two front sprockets, biasing the chainline upwards and downwards at the rear. In the extreme, a cross-chain would be worse than in an extreme in a 2 x system.
