chain lubricant
david k
david k
Hi
North West
wipe and lube, wipe and lube, i got it
ive ordered that stuff off ebay, bike desperate for a clean, ill wait unti the lube comes and give it good sort
the kids have new bikes, ill do their at same time
i remember as a kid using vasaline, i guess that aint very good as the much will stick to it and then get clogged up
Angelfishsolo
A Velocipedian
It will attract grit and as you say get clogged up.
david k
david k
Hi
North West
i will ignore that old advice, i guess things have moved on since! ill use the mickle method and the new lube when it comes, im thinking of getting a stand, 20quid on ebay, do you use one?
youngoldbloke
Funnily enough I'm just come in from doing that...
Ingredients
1 Jar of Olives
1/2 pint of white spirit
Instructions
Remove Chain, (PowerLink helps)
Whilst removing chain,eat olives.
pour white spirit into empty jar
pour chain into jar
Agitate, you may require some rumba music for this...
remove sparkly chain and drip dry.
Lubricate with ungent of choice
Green or black olives? Brine? Should I rinse the jar before adding white spirit? Can I use an empty pickled beetroot jar instead?
Nah - don't think I'll bother - I'll just wipe the chain - and apply Progold Prolink as usual.
WILLIS47
Ingredients
1 Jar of Olives
Instructions
pour chain into jar
WILLIS47
Did mine like that last week.
Little yellow Brompton
A dark destroyer of biscuits!
Bridgend
Seriously look up the Mickle Method. All cleaners leave residue that if not removed prevent lubricant from working properly. All you need is a rag and patience.
That will leave the plates nice and shiney, how do you replace the grinding paste on the bearing surfaces with lubricant?
Hip Priest
I spray a load of GT85 on the chain, then wipe all the dirt off with a rag, then put a blob of oil (usually too much) on each link. It's hardly the most sophisticated method, but I ride an Apollo, and most of it's little brothers and sisters probably never see a drop of oil in their lifetime.
