youngoldbloke said:+1
- and apply it using one of these http://www.pearcecycles.co.uk/product/177
I have used nothing else from new - 18 months, with no measurable wear to the drive train so far. Little and often, wipe off any surplus after application. The Luber allows you to get the lube exactly where its needed.
youngoldbloke said:- yep! admittedly you could use a hypodermic, but they are not quite the same. The body of the Luber is flexible so that the flow is controlled by gentle squeezing. The 'needle' unscrews from the body so that it can be refilled, (and has a replaceable cover for the tip). [It also has a pen type clip so that you can keep it in your top pocket - if you should wish to...]
In brief, no plunger, easier and cleaner to use - but if you have a handy source of syringes, why not? The important point is that you are not slopping (expensive) lube all over the place.
jimboalee said:There is also the 'Pipette'.
