AlanW
- Not to sure?
I'd be interested if the OP has encountered any issues with the chain length and being able all of the possible gear ratios by fitting a smaller chain ring?
(Mod Note: post moved from another thread)
l have recently fitted a sub compact 30/46 chainset, coupled with a 11 speed 11/34 cassette.
I appreciate that cross chaining isn't really advisable to do, but sometimes it's done.
With the current cassette (11/32) l can utilize every possible gear option. However, I've just fitted a 11/34 cassette and when its on the 30 at the front and the 11 on the cassette the chain is far to slack, but the 46/34 combo works fine. So the mech clearly has the range to be able to do it.
I removed one chain link and now the only gear ratio not possible to use is the 46 on the front and 34 at the rear as the chain is now simply not long enough to accommodate it.
In truth it's not really a problem as it's a less than ideal chain line. My only issue is that if l do go to select that ratio by accident it will probably either snap the chain or worse case, rip the mech off the hanger.
I've looked at maybe fitting a rear mech extension, but l dont think that's the answer as l don't have an issue with the clearance between the jockey wheels and the largest sprocket on the cassette.
Any thoughts?
Any thoughts?
