Chain jumping off lower pulley
Mike_P
Harrogate
Had what I thought was a stretched cable to the rear derailleur but after much fiddling could not get the irregular noise of the chain slipping on a cog to go away and then, with the bike upside down, spotted the chain running on the side of the lower pulley. Is that pulley unduly worn?
532423
The derailleur was new earlier this year.
Yes, the jockey needs replacing, but why - I think your cage might be bent or the drop out - not seen wear like that before.
PS don't ever diagnose problems with a bike upside down (hate folk doing this even wheel changes), or turning the pedals the wrong way. Your bike doesn't work like that, and you'll get ghost shifts. You could get new jockeys for a tenner.
  • Like
Reactions: C R
Ming the Merciless
There is no mercy
Inside my skull
Teeth don’t look unruly worn. They’d be sharks teeth if so. Sometimes a chain can jump off The lower if you hit a bumpy bit and the derailleur doesn’t hold the tension well enough. More common on mtn bikes but roads are getting tougher. Put chain back on lower wheel and see how you get on.
  • Like
Reactions: C R
Exactly. It always surprises me that problems can be diagnosed with the bike in an unnatural position.
My thoughts too. Seem to be plenty of life in those wheels. They can be almost worn away and still work.
Not enough info to diagnose accurately.
  • Like
Reactions: C R
The lower jockey doesn't look right - might have been stiff as the teeth should look like the top jockey.
Ajax Bay
East Devon
Keep those jockey wheels out of the 'blame game'. Both the wheels in the OP image are fine (see first one below).
When they wear they go 'ninja' (images 2 and 3 below ).
The dark and difficult to see image shows the chain 'cross-chained' largest sprocket to large chainring (I reckon). The tension jockey wheel has a job to do, more so when cross-chaining. And I agree with @fossyant's 'deal with the bike the right way up' plea.
How irregular? Or is it regular? How do you know that the irregular noise is "the chain slipping on a cog"?
Can you hear it on all sprockets or just one? Does which chainring make a difference? Can you hear when applying power (ie up hill or starting)?
Mike_P
Mike_P
Harrogate
The chain was on the smallest chainring, it was lubed on the 16th (Fenwick's Professional) and has since done 106 miles, 6243ft up. The reason for flipping the bike was to tighten the cable bolt using an Allen key bit in a screwdriver and that's when I spotted the chain off the wheel. Another photo;
532475
Think the cage is bent:sad:
