Angelfishsolo
A Velocipedian
- Cwmbach, South Wales
You should apply for a job there am sure you would fit right in .![]()
I would have though with you 20+ years of experience you would be far better suited to the post than I.
Dont put yourself down am sure with time you will figure it out.
LMAO. Says the man(?) who needed to remove a chainset to free a chain!!!!
Don't get your panties in a bunch. You posted on an open forum, what did you expect?Good comeback LOL says the man who argues with strangers on a forum with something that dosnt concern him!!!!!!!!!
Fair do's. Think everyone is of opinion it was not shops fault. Best to say nothing else until the shop has seen the bike. Please let us know how you get onWell I didnt expect people with hidden agendas trying to hijack the thread or why someone with zero interest in helping me would even bother posting,I honestly dont get it .
Maybe you can enlighten me on this without the insults as I find a little bit of banter funny but two strangers insulting each other on a forum is just moronic,Im not saying either of us has dropped to this level YET.
Fair do's. Think everyone is of opinion it was not shops fault. Best to say nothing else until the shop has seen the bike. Please let us know how you get on![]()
Looking at the pictures, and the one of the BB area, it looks as though you've carried on pedalling. The paint is worn off to the carbon under layer to the front - that's not a one turn drop - that's quite a number of turns for that to happen.
The extent of scratches don't tie in with a half rotation.
What have you been doing ?
I can see the shop's point of view - a lot can happen in 5 weeks, what's to say the mech wasn't knocked ? As it's band on, it won't be torqued up like on steel frames, so may have slipped under a heavy change.
Shouldn't happen, but it can. I'd have fully tested all gears before hitting the road. The way to adjust a front mech is that in the lowest front cog and largest sprocket, the cage should just clear the chain so no rubbing, but you have to road test this, and the shop won't do that as it's brand new.
I've dropped chains in the past, and I've, at worse, ended up with a paint chip and an oily mark, never this amount of damage.
The extent of the scratches is caused by the type of frame and triple crankset combo the chain being bigger than the gap between frame and bottom ring which is just recipe for disaster.
You do like pointing this out don't you.
Having had a quick look at both my road bikes with standard double cranksets I can confirm that the gap between the frame and the small ring is also smaller than the chain.
So stop your whinging and accept responsibility for the damage you did to your bike.
You'd have thought that with your 20 years plus experience with high-end bikes you'd actually know how to set them up by now....
I honestly think no-one who has posted on this thread gets it that on this bike with a triple crankset the frame could be damaged beyond repair if the chain comes off just once.
