Chain for Huret 5-speed Chainset
Justified_Sinner
Birmingham
I need to replace the chain on the old Carlton I recently bought and the generic chain on it gives me no indication of what I should use.
From what I've measured and looked up, a KMC 8-speed (7.3mm pin width) should do it. Does this sound about right?
Cycleops
Accra, Ghana
Any 3-8 speed chain will be okay. Decathlon usually have some good prices:
https://www.decathlon.co.uk/p/3-to-8-speed-bike-chain/_/R-p-11456
This has a quick link. You’ll need a chain cuter too.
Measure it against the old one link for link.
Once a Wheeler
…always a wheeler
593187
Available here: https://www.bankruptbikeparts.co.uk...-2x-3-32-114-links-ideal-non-index-bbp2213249
£4.50
midlife
Something like this
https://www.ebay.co.uk/itm/351343640318
Plus a chain rivet tool, I have a Rivoli :smile:
Ajax Bay
East Devon
Don't forget you will likely need a new block to avoid skipping.
Fit the chain and test (power, up gentle hill in large ring and middle sprockets). It may well be the bike has not done many miles, and the sprockets are hardened steel so may have suffered little wear. If it slips, then new block (and can probably fit a 6sp block into the 126mm OLD dropouts).
