ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
It could be worse... You could be a right thicko with an even dumber derailleur!Must be depressing when your derailleur is cleverer than you![]()
Its not a Di2 issue.Must be depressing when your derailleur is cleverer than you![]()
Go on; share your idea and then people can shoot at it.I have an idea what it is, just want comfirmation (sic)
Worn chain and chainring.
anti-cross chaining is the default setting
It will only do that if you proggrame (sic) it.
i (sic) look after a lot of Di2 bikes,
5. When a chainring is worn out, it will produce intermittent chain suck when shifting to the inner chainring, and I suppose it could also cause occasional inward chain drop from the big ring.
I think you can tell Di2 to trim so it adjusts properly. My guess at the moment its just shifting into the big front ring and no more so a shift up the block pulls it back (to the left) slightly which drops the chain onto the small front ring. Trimming might sort that![]()
You got the smiley right.
