overmind
My other bike is a Pinarello
- Reading, Berkshire
I have a utility bike (road bike) for just pootling around town.
The bike has an old-fashioned 7 speed screw-on freewheel. I think it is designed for a mountain bike because the largest ring on the rear sprocket is quite a bit larger that the second largest ring (see below). The gradient of the hill was such that I really needed a gear between the lowest and the 2nd lowest (I was in 1st gear).
On the front this bike has a dual-chainset, so I thought I would try changing to the big ring on the front and that it might give me a gear slightly in the middle of first and second.
This was a big mistake! Reason 1: cross-chaining but reason 2 was worse. The derailleur got stretched to the maximum extent and locked the chain in position. The chain would not turn without grinding metal noises. It was so tight I found it very difficult to get the chain back to the small ring. I had to turn the bike upside down - I did not have any tools with me - and physically push the chain off the big ring as I turned the cranks (effectively using my hand as a manual front derailleur). I could have sliced my finger open. I certainly got lots of oil all over my hands.
I'll have to remember not to do that again!
