I've used Finish Line Chain Cleaner with Finisk Line EccoTech Degreaser it works well. I've also used Finish Line Speed Degreaser (aerosol) which is quick and easier if the chain isn't really mucked up.
I use Mickle, and 90% of the time it's brilliant, but 10% of the time the spaces between the links are full of a well ground paste of glacial sands and our local Cheshire/Shropshire finest cowsh!t. Mickle does not get at that - only the outer surfaces of the chain, so I have to remove the chain, then bath in FS10, wash, dry, re-fit and re-lube. Or am I missing something?
*whispers* You're not doing it right if you have to 'Have to remove the chain, then bath in FS10, wash, dry, re-fit and re-lube'.I use Mickle, and 90% of the time it's brilliant, but 10% of the time the spaces between the links are full of a well ground paste of glacial sands and our local Cheshire/Shropshire finest cowsh!t. Mickle does not get at that - only the outer surfaces of the chain, so I have to remove the chain, then bath in FS10, wash, dry, re-fit and re-lube. Or am I missing something?
Is there a link to the Mickle method . A search throws up lots of people saying use it but no method![]()
Given the fairly short life of chains you'll get away with it. Trouble is it leaves all the grinding paste on the outside wearing down the transmission.I gave up cleaning chains years ago, believing that using solvents washes grit into the rollers and shortes the life of the chain. Now I just lubricate each roller regularly and am convinced that my chains last a lot longer than they did when I use to clean them, in fact they now outlast most other components on the bike.
