Chain Cleaners?
dodgy
I clean my chain with a rag after every ride and it shines with clean goodness, no grinding paste on my chain.
BentMikey
Rider of Seolferwulf
South London
Chains are like helmets and hiviz. All religeon, and little real right. ;)
knonist
I wonder if solution of fairy liquid & warm water will do the same job.
After all, farry liquid is a degreaser.
tandemman
I put mine in an ultrasonic bath filled with jizer then stem clean it then oven dry then bake in a synthetic grease in a low temp oven then polish it. It only costs £50 a time and takes three days so well worth it.
Plastic - a wonderful engineering material which has many uses, but gets over-used and manufacturers don't always pick the correct type when speccing products.
I bought a Park CM-5 chain scrubber. The first one lasted one use and the plastic around the metal clip which secures the top and bottom together when the cleaner is being used crazed and cracked off. I sent it back, the bike shop sent another out and it arrived cracked in the same place.
Got a refund and bought the Halfrauds Bikehut Chain cleaner kit. Again, made of plastic and will therefore break in time, but works for now.
I agree with the concerns about solvent cleaners washing off all of the lubricant from the chain, also that unles you are a pedant it won't all come out of the chain and will probably wash off some of the lube you apply.
I think when my current chain scrubber dies I'll switch to the Mickle method, or a mix of it and others.
Does anyone make a belt-drive bike, that'd get rid of the chain problems :smile:
p.s. speaking of plastic being used to make inappropriate things, anyone remeber the Itera Plastic Bicycle? I remember seeing them in bike shops in the eighties, interesting to read about them now!
Garz
Squat Member
Down
Browser said:
Does anyone make a belt-drive bike, that'd get rid of the chain problems :biggrin:
Yeah there are a few out there, I seen a new trek one in the lbs last time I went in, looked kind of funky.
