Chris S
- Birmingham
I've just adjusted the caliper brakes on my Raleigh.  On brake block is now a lot nearer the rim then the other.
According to my Haynes manual the brakes should be centred by rotating the brake body using a spanner. However my brake body appears to be fixed in one position, it doesn't even have the flats for the spanner.
Does it really matter if side-pull brakes aren't centered? The braking force is disproportionately greater on one side than the other no matter where the brake blocks are.
