G3CWI
- Macclesfield
I would suggest you measure your chainline
I will do this when I get home. Thanks for your interest.
which says
I would suggest you measure your chainline. If it is a double it is the distance between the centre of the frame and the middle of the two chainrings. If it is a triple to the middle ring is good enough. Then come back with the measurement. It should not be far from 45mm given it is a road bike. Also please provide the make and model code of the front mech (if it is a Shimano the code is something like FDxxxx)
The solution that you think is the solution to the problem is not the solution.
41mm. There is no part no. on the front mech that I can see. It is labelled Sora Triple.
Also, although I cant photograph it, there is a dent in the frame where the mech hits it. I think this was done as an after-thought by the manufacturer when they realised there was a geometry problem?
Ounce Pro-wheel 50/39/30.
Hi. It was new. I will grovel about and look for the part number. Cheers.
No sign of a number. It's reasonably clean and I have looked at all the visible parts.
it begs the question whether it was done with management authority, whether it was done en-masse, and whether it compromises the integrity of the frame.
