Cassette removal problem
Dwn
I'm in the process of changing the wheels on my Triban RC520 and RC500. The latter bike is a couple of months old and the RC520 about 18 months.
The cassette on the newer bike came off without too much effort , but the older one seems stuck fast. Any suggestions to make this easier, or do I just need to apply more force?
Thanks
Hampshire
When you say 'stuck' assume you mean the lockring, if you're using a loose lockring tool use the QR skewer to hold it in place and maybe a longer spanner, try to get the spanner and chain whip in a position where your pulling them together.
  • Like
Reactions: Dwn
Cycleops
Accra, Ghana
Always useful to have a bit more leverage, slip a length of pipe over the spanner which should give you a bit more power.
Stand behind the wheel with the chain whip on one of the larger sprockets.
  • Like
Reactions: Dwn
Dwn
Dwn
Yes, it's the lockring that is stuck. I've got a removal tool which has a handle included and a chain whip. Will try to find a pipe for extra leverage. It may not need massive force, but a week of lower back pain has left me reluctant to apply too much force in case of sudden wrenching movement.
ColinJ
Puzzle game procrastinator!
I have broken my chainwhip twice trying to remove stubborn lockrings. I ended up with a very strong DIY chainwhip ...
I gave up on repairing the chainwhip, though I will repair it again later for routine maintenance. This job clearly needed a chainwhip on steroids so I made one which would be up to the task in hand. Or rather - foot! I hammered the bottom of the sprocket into a big piece of timber and screwed a length of chain over the top of it.
I balanced the timber on the edge of a patio and put one foot on that to stop it moving. I then stood on the 12" spanner with my other foot. It took some bouncing on the spanner to finally get something to give...
... which was a tooth on the sprocket, which I managed to snap off! I tried again a couple of times and I finally felt the lockring move. Hoo-bloody-ray!
It took quite a bit more effort to unscrew the lockring; there did seem to be some corrosion involved in the problems I'd been having.
  • Like
Reactions: Dwn
Gunk
Oxford
I’ve ended up having to scrap the cassette by putting it in the vice and then using the lock ring tool with a breaker bar and additional steel tube. It came free in the end. It was a commuter bike which hadn’t been cleaned for over 10 years. Plenty of swearing helped!
  • Like
Reactions: Dwn
Cheshire
You just never know how it will turn out, got one off earlier without chain whip, couldn't believe my luck, fettling is certainly an inexact art :blink:
  • Like
Reactions: Dwn
Dwn
Dwn
Have you tried standing/Bouncing up and down on the pipe...? (Either the lockring will come loose, or something will break!)
I suspect that the something breaking might be on me rather than on the bike! I had hoped there might be some secret to it, but the more I read, the more it seems more force is the only answer. I'll give it another go in the morning, but I think I'll be buying a new cassette. Luckily, a father's Day voucher for decathlon will cover the cost
rogerzilla
They don't need to be very tight. There is a torque marked on them but the tool most people use doesn't easily fit a torque wrench, even if you have one in the right range. A few clicks of the ratchet.
  • Like
Reactions: Dwn
