please explain what the numbers are on the chain set in a simplistic form and how this would help in the actual riding of the bike.
A chainset is a crankset with chainrings. There may be one, 2 or 3 rings (and
@Ian H will have an image of one with 4 ) - current vernacular: 1x, double/compact/semi-compact, triple.
Combined with a sprocket at the rear this allows the rider to 'gear up' (or down) their pedalling to produce a torque at the rear wheel to enable efficient forward propulsion.
Number of teeth
Each ring has a number of teeth eg 48t. When the chain is on that ring and a 12t sprocket at the back, the gearing advantage is x4: so every turn of the cranks turns the rear wheel 4 times. A reasonable/typical cadence (number of revolutions of the cranks per minute) is 80rpm. So @ 80rpm in the 48/12 combo with a wheel circumference of 2.1m means the cyclist is travelling (and applying effort) at 80 x 4 x 2.1m (= 672m) per minute or 40kph / 25mph.
With that top gear a cyclist can pedal faster (higher cadence) but sooner or later the cyclist will 'spin out' and no longer be able to pedal fast enough to apply any force to the pedals. With this gearing the speed at 120rpm would be over 37mph and most riders would have gone into a tuck and freewheel way before then (or be running a bigger gear eg 52/11).
Up a steep hill a cyclist will use their smallest chainring - say a 36t combined with their smallest sprocket (say a 32t): a gearing ratio of 1.125. Cadence will likely be lower uphill (YMMV), say 60rpm, so the cyclist will ascend at 60 x 1.125 x 2.1m per minute = 142m per minute or 8kph / 5mph.
If a cyclist tries to climb a hill with too high a gear they will reach the limit of the force they can apply to the pedals and 'stall': being forced to stop - falling over optional.
Have a play with this
Gear Calculator.
Bolt centre diameter (BCD)
Chainrings are bolted onto the right hand crank with bolts: typically 5 or 4. The circle the bolts are on varies in size and different makers have chosen different variations: their size is described by their diameter their BCD. Typical values are 135mm, 130mm, 110mm and 74mm but there are many more, and a new or replacement ring must be exactly correct (BCD and number of bolts). See this
Sheldon Brown link for more.
HTH
How many teeth have your chainrings got,
@Brummie53 and what is the range of your cassette at the rear (eg 11-32)?
