Cassette compatibility?
Willam
I have a 11-42 shimano cassette 10speed, need a new one but none available anywhere, can I change to any other 10 speed cassette, I'll be changing the chain at the same time, the rear mech is a long cage, will I need to keep the new cassette to a certain size to accommodate the longer cage?
T4tomo
any 10 speed Shimano or SRAM / shimano compatible cassette will be fine (but not Campag). your long cage is fine, its going the other way (adding larger sprockets and over stretching a short cage you need to worry about. Cleary if you go for 11-25 you'll have lost a load of low gears but that is stating the obvious. good luck hunting stock down...
Willam
Willam
Great cheers for that answer.
yeah unbelievable, I had one of those government vouchers, went into Halfords to spend it, they didn't have any stock of anything I needed, ended up just getting a spare mech.
Aren't those meant to be used for maintenance not free spare just in case parts? :wacko:
Willam
Willam
Aren't those meant to be used for maintenance not free parts? :wacko:
They were meant to replace parts that need it and maintenance, I'll be replacing it when I source the rest of the drivetrain, as it all needs replacing, I wasn't going to replace a new mech on a knackered drivetrain, the mechanic agreed best to replace all at the same time, as he couldn't provide any of the other parts he agreed to let me fit it when I had the rest of the parts.
Have to say, I wasn't expecting a good experience from Halfords but the mechanic I spoke with was excellent.
I’ve linked a 10 speed sun race cassette for you. Chain should be easy enough. Don’t restrict yourself to Shimano only as above
Willam
Willam
good options there but I'm a little nervous using none shimano...which of those links would you say was the better option, I use the bike for daily commuting, it's a 1x drivetrain not sure if that makes a difference, the odd small hill.
Why? A branded cassette is a cassette and a chain is pretty much a chain. The manufacturer just happened to stick Shimano on, as above there's lots of cross compatibility (very useful in a post-Brexit pandemic!!). Doesn't sound like you have a choice (unless there's something on eBay or you want to order from abroad)
My bikes have SRAM shifters, but I use Shimano cassettes as they are generally cheaper, with zero issues. KMC make well regarded chains
T4tomo
as above, a cassette is a cassette. as long as compatible select on price. Higher price normally means its 6g lighter and wears quicker.
KMC chains are better than shimano ones
Willam
Willam
Is the KMC X10 chain a good option? Or would the sram PC 1051 be a better option?
Personally, not used non-Shimano cassettes. Yet. Have invariably changed to KMC chains, they are the business, but as @vickster and others have said, a chain is a chain...
As I'm about to start looking for an 8-speed cassette again, the Sunrace items are looking pretty attractive, and, more to the point, attainable!
