Cassette advice for newbie!
Degsie73
Regular
Billingshurst
Recently purchased a Planet X RT 58 bike which came fitted with an SRAM 11-26T cassette and a FSA gossamer compact 50-34T chainset. Apologies for my ignorance on this but I'm fairly new to it all - I've been struggling somewhat on the steeper climbs around me! Am I right in thinking that I can change one or both of these components to make life a little easier - if so what would people recommend?
It also has Shimano Ultegra 6800 shifters - if that makes any difference. I appreciate that I need to work on my hill climbing/ fitness also, but I can't help but feel like I need a lower gear or two on the steeper climbs (bury hill - West Sussex destroyed me last week).
Any advice appreciated thanks!
lpretro1
if you are new to cycling then it may just be a question of fitness mostly - you just need to build up gradually and accept it will be hard on the hills - it always is!
If you have the 6800 then you should be able to fit a cassette with a big sprocket of 30t or even 32t which would give you a little bit extra on low gears. You may have to lengthen chain however
mrbikerboy73
Worthing, UK
@Degsie73 Bury hill is a killer no matter what gears you have. I can get up there with a 34/28t but I'm nearly dead when I reach the top!
New cassette and maybe a longer chain is the way forward. The rear mech will only take so much before it needs to be replaced with a longer cage type. Any more than 30t (I think) and you'll be looking at a new rear mech too. Anyone feel free to correct me if I'm wrong :smile:
wayneo
I bought the same bike a couple of months ago and had the same issues...i bought a 11-32 cassette and had to buy a longer cage ( medium ) but the chain was fine. Lbs fitted them for me for £20. Sold the ones that came off on ebay. Hope this helps
DRHysted
New Forest
None of my bikes have anything smaller that a 30 as the lowest gear on the cassette. I find it frustrating when reading reviews and they write "you can get up any hill with this" talking about a 26. Well yeah you maybe able to get up them but us poor amateurs need to be able to proceed with the ride afterwards, and not lie in a heap hyperventilating.
As you may guess I struggle with hills. The Roubaix has 12-32, Allez 11-30, Boardman 11-32, MTB 11-32.
Pontefract
I ride a 12-23 rear with a 26/38/50 front gets me up most things on the middle ring, but then the riding here isn't very difficult in terms of climbs. Just a couple of short climbs worthy of note.
TheJDog
dingo's kidneys
28 is quite a bit lower than 26. I'd get an 11-28 first and try that out before thinking about a new rear dérailleur. if it's 11 speed, SRAM, Shimano and Campagnolo are all compatible. 10 speed SRAM and Shimano are compatible. Find the cheapest cassette to try out?
SpokeyDokey
I'm with you on this nonsense for those of us that live in the real world.
I have switched from 46/36 - 12/28 to 46/34 - 12/30 and the lowest gear makes a massive difference to me.
It's pretty hilly where I live and no way could I get up many of the local hills on a 34/26 combo. Even with 34/30 once I get into gradients of 10%+ I can only get up short-ish climbs before I am really feeling it eg 4-500m and really long 6/7/8%'s whilst do-able take a fair bit of twiddling and puffing. I wouldn't even begin to attempt the mid to high teens and and beyond that are evident on the local mountain passes but no doubt someone can get up them on 39/23 without breaking sweat.
Each to their own ability of course but there has always been a little bit of macho-ness in cycling.
Pontefract
Me I ain't macho, :whistle:, just don't get conned into only real riders, ride doubles, otherwise the compact double would never have come about, I can get up some 15% on my 38th middle but the 23th rear whilst do able on the local ones, I know hills I will be down to 28x23 or 34x28 in new money and wishing I hadn't took that 26th off. :laugh:
