If after a couple of years of all weather use, you get a problem with a Square Taper cartridge system you need to urgently replace the cartridge within the next few thousand miles.
And then, of course there are old fashioned "proper" bottom brackets, with loose ball bearings.
Depends on the type of press fit. The BB30 type where the bearings are set into the shell of the frame are the worst for creaking as the shell can never be manufactured to a perfect round - whereas those with plastic supporting cups such as the Shimano pf much less so as the supporting cups allow room for imperfect tolerances. Creaking also can be worse if you have a pf bb with adapters for different crank sizes to the original.The one thing i know is that the press fit bottom brackets is prone to creaking.
I'm about to fit a new UN300, so I'll make a note to check back in 10 years to let you know...Re my other thread, they have of course discontinued the things - can't be having stuff lasting that long.
They have to be fair introduced a new square taper, though I have no idea how it stacks up against the UN55.
I don't suppose anyone has taken one apart or yet had the opportunity to do a long-term, like 10 years, test.
@Dogtrousers
Cheers, yes it only does it normally once, then not for a while but its started giving 2-3 "clanks" in one go now.
It does it on the big and middle ring, sounds from the front somewhere, I was wondering about the front chain rings, I had the chain and rear cassette changed in the autumn, the chain was well worn.
The LBS id a great job of the chain and cassette, might go back to them. Its hard for them thou, as its does not do all the time.
Oh, I had better double check my knees of course
It is odd that BB went to external cups just after headsets abandoned them. Since ST there have been quite a few different standards that try to incorporate hollow axles with smaller bearings. They cannot match the old standard for fit and forget everday use.
Not that complicated, but you need a specific tool, which will cost you more than £30 to buy......so get the bikeshop to fit itI started to get creaking from my bottom bracket and I queried whether this was dangerous and bikeshop guys said no. I asked them to replace it for me and was only £25 for the new press fit BB. Was £30 for the labour costs. Do you think the creaking is dangerous or can be? and is fitting such a bb that difficult it can be done by a novice mechanic?
The word so far is that failures have occurred, with subsequent dismantlement, and that they are a substantial step down from the UN55 type, being an axle with shoulders for a pair of cartridge bearings accommodated in the end cups, with a central sleeve.Re my other thread, they have of course discontinued the things - can't be having stuff lasting that long.
Press fit has been around forever on BMX - nothing newPF30 is the usual culprit for creaks. It's a version of BB30 (and uses the same cranks) but is designed for lower tolerances, with plastic bearing housings.
The big pressed-in designs allow carbon frames, with their fat tubes, to flow around the BB area better, as well as offering extra stiffness you probably don't need. And bike manufacturers always like inventing new things for no reason.
