Nigelnaturist
- Pontefract
@Dogtrousers great minds and all that.
Indeed, thats what i get for posting after getting home from nightsIt doesn't always work, depends on the rings and cranks.
@johnpenn81 as @Mongoose says the P.C.D. or B.C.D. (Bolt centre diameter), it can be worked out from measuring from centre of one hole to the centre of the next,
and then use this table to work out you B.C.D. most are pretty common 130mm normal double, 110 compact doubles (this is why they are compacts, not the chain ring sizes), you can't fit a ring of less than 38th to a 130mm its why they use the 110mm for the 34th, 74mm BCD is usually used for the inner ring, though Shimano triple use different sizes, my prowheel has a really odd size in that i cant find a size to fit. Campagnolo double is 135mm BCD so it is important to check them.
@Mongoose @Nigelnaturist Thankyou so much for this guys really appreciate it. To be honest i didnt realise there was so much to learn!!
Good news is I have had the new front ring on and changed the cassette to a 11-28 as per your suggestions. Took the bike out for a long ride yesterday and the gearing is now perfect. Hit a couple of hills with steep section in the dales where is gets up to 15-17% for a few hundred metres and i could actually turn the pedals over now.
Really makes a big difference to the enjoyment factor of a ride when you know you have made it to the top of a climb on the bike and not had to get off and push. Big thanks to you both for all your help.
My wife also sends her regards as I had been talking her into letting me ditch the TDF & spend a £1200 on a bike with better performance. Think i have everything I need now for a while yet![]()
Tongue in cheek mode engage ............
MTFU , when i was in my twenties i rode a gas pipe bike 52/42 with a 13-19 block !,
exit mode.
Hurt like hell on hills mind .
In my late teens I had a Gitane can't remember the rear, same front as it was pretty standard, but I am not in my teens and I have better choices how I want to gear the bike, I may well end up with a 12-23 cassette, pretty much the gearing on this 50/38/26 as was on my 52/40/30 12-27 just better geared on the 50 and 38 with the option should it be needed, remember my bike can weigh up to 20Kg's and maybe more with the rack and panniers.Tongue in cheek mode engage ............
exit mode.
Currently the Halfords website says the TDF should be fitted with:
OVERVIEW
The Carrera TDF has had a serious dressing down. The model prior to this had the Prowheel 52/42T chainset at the front and SRAM 12/26T 8 speed cassette at the back with Shimano Claris 16 speed gear shifters. The front chainset with a 42T inner ring may have been ill-conceived but, on this version, with small tweaks to the front and back gearing, you could get a lot of bike for not much money. This is not the case with the latest version with the spec you have detailed. It may boast a 50/34T compact double chainset but, at the very least, it has taken a step back with a smaller range of gears and inferior gear shifters. Also, in my experience, the 50/34T arrangement up front is a hard one to manage comfortably with such a big step (16T) between the two front rings.
Nice, they will make the bike a little lighter (maybe 1lb )and go for it if you can but the weight saving will only help slightly and a more effective upgrade will be a gearing change, a quick method would be a longer cage rear mech, wider range cassette + chain or as already stated above a new BB and compact chainset .Been reading this with interest..... I've got a TDF 52/42.... hills are not nice... legs burn and I'm already in bottom gear!!
I'm going to have a read tonight at home and decide what 'treat' I get myself along with a set of 105 wheels to make the bike lighter.
