so my comment wasn't completely useless then! You say you don't have much money, but are wanting to spend money on a secondhand carbon fork to reduce road buzz - now that is just wasting the little money that you have. fit some 25mm tyres (assuming you have enough clearance) and ride them at no more than 100 psi - problem solved, without spending much money. You could even fit 28mm tyres if you have the space.Thanks for the link vickster and that does look great but I haven't got £300! I might be able to get one on the cycle to work scheme but even thats pushing it.
I wouldn't be spending anywhere near that on a set of second hand forks!
These might be a reasonable upgrade over stock wheels at just over £61 (and quidco), plus around £20 for rubino 25mm tyres
http://www.merlincycles.com/shimano-wh-r501-clincher-road-wheelset-49086.html
Hi,
I have a Carrera TDF from 2011, bought on the cycle to work scheme. Is a good bike for what it is. Since getting into cycling more my garage has tripled since then, but I still use the Carrera as my commuter for all weathers.
Upgrades I've done:
Tyres (Durano Plus 25MM) - Excellent tyre - recommended New ones every year
FSA Omega Compact bars - Cheap and suits me better for riding in the drops
Double bar tape - to help with the road buzz on the crappy Dublin roads.
Clarkes triple compound brake pads - change when neccessary
That's it! I agree with the above posts in saying a (cheap) carbon fork will not kill the road buzz you are trying to achieve any more so than better tyres and / or double taping would. Plus the uncertainty of a 2nd hand carbon fork scares me.
The TDF is a good bike for what it is, keep it well maintained and you will get a lot of use and fun from it. Me personally would look at other areas to upgrade before adding a 2nd hand carbon fork to it.
if you do some research you'll find that 'tread' on bicycle tyres doesn't provide more grip in wet conditions on a smooth road - the rubber compound is more important and slicks work perfectly well. If you are riding in mud or on gravel and loose material then that's a different matter!I have already changed the wheels for some Shimano R500's which helped quite a bit so I'll be looking for some wider tyres I think.
Any recommendations for 25mm+ tyres with plenty of tread for wet weather riding? I don't want to go as far as CX tyres but want more tread than the slicks I have.
