Car fuses - dumb girly question
Willow
Surrey
I need a new fuse (Vauxhall 10) does it need to be Vauxhall specific. The V garage is not very close and I'm confined to base for boiler service then back at work. or will the little MOT place 5 mins walk away have somethng that will do?
Rhythm Thief
Ross on Wye
Any fuse will do, as long as you know the rating (10 amps, in this case) and what shape it is. Most modern cars use blade fuses. Your local garage should be able to help you.
ChrisKH
Essex
You would be better off going to Halfords or a local car shop. A local garage will not supply unless they also fit. And these things are really easy to do. No it doesn;t have to be Vauxhall specific but it must match.
Mr Pig
They come in two sizes though. Most are the smaller ones but some older cars might still be the big ones.
They're cheap. Buy a few different ones and keep them in the car? In fact, are you sure you don't have one? Many fuse boxes have spare fuses clipped next to the 'working' fuses.
