I changed my auxillary belt up post....I still have an occasional, sometimes persistent squeal
Things to consider....
It's not there all the time, it seems to be in the belt/ pulley area.
There is no power steering pump, electric rack.
I've sprayed some WD40 in the tension pulley bearing area, doesn't seem to make any difference.
I've sprayed the belt, doesn't make any difference if its squealing.
When I stop the engine, I usually get a quick 'chirp'
Strangely, if I turn the steering wheel slightly...the squeal stops, but comes back as  I straighten up.  But I have an electric rack, no power steering pump running off the belt.
Air con...seems to work ok, compressor clutch therefore assumed to be ok.
Brakes ?  Mine does have audible warning plates on the pads and I know the pads are getting low...but the squeal is sometimes there when I'm static.  Brake backplates discounted for the same reason.
Gearbox is a known issue on some Astras, mine doesn't have the notorious one and my shifting is smooth as ever.
Water pump ?  Why would it stop squealing when I turn the wheel  if it were the pump ?
Belt is coming off again in the next few days, will probably clean up the pulleys thoroughly in case they've become glazed or dirty.  Cant see why alignment of pulleys should be a problem, nothings been moved or changed (other than the belts of course)
Somewhat annoying eh ?
I do need to consider it might be the tensioner losing tension with age, rather than the tensioner bearings.
