1.6 Laser, September 1986.
I got all excited, I thought it was a 3.0S. I owned one back in the early ‘80’s
Oddity?
Daughters car had refused to start this AM, all it would do was unlock & click all its solenoids at me
Went out again, this evening, & it wouldn't even unlock, so we pushed it out of the garage, & jump-started it from my Octavia
Thus, I went for a trip in it, to try and charge it a bit
Up the M62, to Whitely Bridge
En-route, all the dials kept going to zero, staying there a while & coming back to correct readings
The 'smart(?) display' kept showing 'check air-bags', check tyre pressure system', 'check anti-theft'
The radio wouldn't come on at all
At the moment, I'm just presuming that the very low voltage upset a few systems, & that they will stabilise after a few 'reboots' (stop/start/lock/unlock cycles)
Is that a reasonable hypothesis?
Vauxhall Adam 1.4 petrol
(2014)
Pretty nifty
Once the keys were coded I finished it off at home and got it all up and running together...
Needs a new windscreen so saving my pennies at the moment. but I have the camera module and loom ready to go, so I'll probably run the cables in the near future and poke it all out of the way until I've got the new screen fitted then make the final connections and coding.
4 wheel drive, 295bhp and 430ft lbf but still averages 50mpg and is super comfy on long journeys, all rather silly really
Of course I hadn't backed it up, and its unique to every vehicle as some of the code is calculated from the VIN, so I had to spend about 10 hours rewriting a 30 byte hexadecimal code piecing info together from various forums to clear the 52 error codes i had cleverly created
I got it driveable again and had the original code reinstated when the speedo was online coded. Amazingly I'd only got 9 bits of the 30 byte code wrong, pretty happy with that
I have just one thing to say @JhnBssll ...fooookinhellllll
Sounds like your preparing the car for a Pluto trip![]()
That looks really smart. What do the orange markers in Pic2 tell you? Or is that a reflection?I've been making some changes to my new (to me) Passat estate over the past few months. The car is a replacement for the one that VW kindly ruined whilst undertaking some warranty repairs and since this particular model is fairly hard to come by I accepted a model without some of the toys I would have ideally wanted. Fortunately VW group cars are relatively easy to muck about with and there's plenty of info online regarding retrofitting of components and systems
First to be fitted was a reversing camera, which pops it's little head out from under the VW badge when you put it in reversePretty nifty
This is an OEM camera but VW aren't kind enough to put cables in unless the items are specced so I had to run the new loom from the boot lid to the glovebox and connect it all up to the CAN data bus, then code the new camera module in to both the park assist module and the infotainment module ...
Spurred on by my success, I bought the latest and greatest infotainment module and screen, as well as a virtual cockpit speedo unit, both second hand on ebay...
These were a bit more of a pig to fit, with some of the coding being out of my depth. I fitted the stereo but had the speedo coded for me as its linked to the immobiliser - it needs to be coded online whilst connected to VW servers with expensive software I don't ownOnce the keys were coded I finished it off at home and got it all up and running together...
Pleased with that!
Next jobs is retrofitting the front camera unit, which will enable lane assist and various other featuresNeeds a new windscreen so saving my pennies at the moment. but I have the camera module and loom ready to go, so I'll probably run the cables in the near future and poke it all out of the way until I've got the new screen fitted then make the final connections and coding.
I've also just received the latest park assist module and sensors which will mean the car parks itself, as well as the side assist radar modules which warn when there's something in the blind spot and make the car actively counter steer if you try and side swipe something
I would like to retrofit the electric tailgate at some point too but it's expensive, so I'll wait and see what turns up in the local scrap yard
It's also lowered slightly and remapped4 wheel drive, 295bhp and 430ft lbf but still averages 50mpg and is super comfy on long journeys, all rather silly really
