lurcher106
Member
- London
Hi everyone, hope you're all doing well!
For a while now I've been working on a nice little peugeot, disassembled it, and stupidly threw away the old chain for reference.
I followed this sheldon brown guide for approximating the best chain length but am having some weird trouble.
https://www.sheldonbrown.com/derailer-adjustment.html#chain
When I set the chain from the largest chainring to the largest cog on the back, bypassing the rear derailleur, I end up with an odd number of links in sheldon's left hand diagram. this means that i'm really, really close to being able to pull the chain just a bit tighter and being able to get it on nice and tight, but the bike just won't allow it, and if I set the chain up to match the diagram, it's got loads of slack and is much too loose. The chain I have is an SRAM PC850 Powerlink. It's for an 8 speed but the guy in the shop told me it would be the same width as a 5-speed chain, which the peugeot is.
Looking at the rear wheel, there's been a strange issue with placing the wheel. Because of the way this rear mech fits, it kinda pushes the rear wheel forwards on its axle.
I'm thinking this is making the chain length difficult, but I can't find any other way to fit this rear mech. If you look at the photo, the previous placement was further back. For what it's worth, the way it's setup right now is also kinda forcing the rear triangle outwards, as if the whole rear axle is 1/2cm too wide for the frame.
The axle looking a bit wide. (sorry about my foot sneaking in there) Also see the inside of the derailleur, where there is this 'spacer' thing.
Said spacer, closer up. The outside of the derailleur shows a nut which tightens this into place. It's this thing that is effectively pushing the whole wheel forwards, but I have no idea how else it would be installed.
It's a lot like this one here:
Sorry the photos aren't great, I've been too busy to take anything apart but can happily do so if it's required to take more photos and get to the bottom of this.
Thanks so much for taking a look at this post!
Fin
Fin
