Can't fold my bike because of missing piece. Also I have a stuck battery.
cyberknight
i think i worked out the seller but the website doesnt show the clamp in the blurb :sad:
cyberknight
That might be because you've got the saddle too low, a typical cause.
Your leg should be more or less straight when seated with the pedal at six o' clock.
chriswoody
Northern Germany
I've seen a few clamps like this on folding bikes on my commute. I managed to grab this picture which may show how yours looks when correctly assembled? It shows the parts you have, plus the missing nut you mentioned on the back of the threaded bar. As Cybernight has said, it looks like a generic nut that you should be able to easily pick up at a DIY store.
Anyway, hope that helps.
cyberknight
thats looks good , a standard nut i guess it would have a plastic ring inside the head to stop it coming undone ? standard fare any hardware store should have one to fit if you take the rest to a shop and ask
rustedchain8919
rustedchain8919
London
Yes, Thank you!
