Maherees
- Northampton
Thanks all. I guess frame flex is unavoidable then.
I made mine after watching this videoI had continual problems with the SRAM 1x gears on my gravel bike. These were similar to your issues. I was recommended to look at the hanger adjustment. So I made a tool to do this and discovered it was badly aligned. A quick tweek and it has been great since. Very easy check for an LBS to make.
View: https://www.youtube.com/watch?v=KIzd0xdkowM
You can buy them on ebay for under £25
I'd agree, his method was rather sloppy and dangerous. This is what I built using a shelf bracket, because it is flat it avoids the issue and is at a perfect right angle.Thank you for sharing. I echo @C R 's caveat, which jumps out at you (well me) as soon as he starts drilling. This tool can only be as accurate as the accuracy (as in right angle) of the 'indicator arm' and the rear axle to the extendable main lengths. Inaccuracies in the metal section drilling is mitigated by the washer and locknut set up, which should pull the axle very close to perpendicular. Less so the plastic elements.
I use the remnants of a broken rear axle (its OD and thread pitch is the same as the threads in the aluminium hanger/steel frame's dropout used to fasten the rear mech) and a piece of tube slotted over that axle stub. With the frame exactly upright the tube needs to be horizontal (I use a spirit level to check that) and perpendicular to the plane of the frame - which I judge by eye (the latter is less important in any adverse effect on rear mech (mis) alignment). Hope that makes sense.
That's good!I'd agree, his method was rather sloppy and dangerous. This is what I built using a shelf bracket, because it is flat it avoids the issue and is at a perfect right angle.
I thought about making one, but then realised that if I wanted to make it right I would need to spend more in the tools required than I would be paying for a ready made one. I wish I had thought about the shelf bracket, that's a brilliant idea and I have a couple of lengths in the garage.That's good!
I gave up on making a diy tool and bought one. Quite small adjustments on two steel frame bikes transformed gear changes from "will it, won't it " to "I don't even think about it anymore"
I’ve only ever been able to drill round holes .... even using a pillar drillDid you do the drilling by hand? I know that without a pillar drill I could not get the holes anywhere near square enough.
The axis of the hole needs to be perpendicular to the bar, that's what's usually meant by the expression I used.I’ve only ever been able to drill round holes .... even using a pillar drill
I thought so ... I was only pulling your legThe axis of the hole needs to be perpendicular to the bar, that's what's usually meant by the expression I used.
Sorry, been a long day today.I thought so ... I was only pulling your leg
