cheshirerob
Evening All,
Looking for some advice please, long story short, when I was last cycling I heard some grinding and knocking sounds, located the noises from the bearing inside the freehub.
Ive stripped the wheel down tonight, but the only option to remove the freehub is from the non drive side, I can see a splined or torx style fitting that is approx 14mm, however to even access this with a tool the non drive side bearing will have to be removed.
Is this the correct method?
I thought with my bike being common there would be lots of people who will have performed this job. The hub is a formula rxc 400 so assume formula freehub?
Cheers
Rob
Cheers
Rob
to the forum.
