When you can hear the chain rubbing against the derailleur cage as you pedal.Hoorah! Thank you, so how will I know when to change/change is needed?
Or Campagnolo shifters using many small clicks rather than 3 main positions.Even better on a down tube shifter, you have infinite trim on the front shifter. No rattles !!!!! OLD SKOOL
Trim is a half click in between changing from big to small as well as small to big at the front. It works on both changes.Ah, I've never heard it rubbing, someone mentioned 'trim' to me in passing and I didn't have the chance to discuss!
Do all bikes have it? Is it just the big ring that has the extra trim click or does the little one also?
If you want to go a cog or two higher on the back whilst still in the small ring then trim helps. Similarly, if in big ring and want a slightly lower gear at back, then trim works here too.
Basically allows you full range at the back on both small and big ring at the front.
It is also possible you have a "admirer" offering you a compliment!
Trim can also mean "in good physical condition", of "Having lines, edges, or forms of neat and pleasing simplicity."
And if that doesn't work, try kicking itOnly use of 'trim' in cycling I can think of is for the front mech.
The clever Shimano electric shift system automatically 'trims' the front mech so the chain never rubs, no matter what combination of front and rear cogs you select.
