Can I swap these two braking systems ?
Stompier
Can anyone point me in the direction on some good info on how to set them up correctly ?
As I said earlier, you could start by shortening the straddle wire, by a lot.
C R
Worcester
Thanks everyone for the info,much appreciated. I have been off the bike for a while now having had a diagnosis of Fibromyalgia a few years back and suffering a lot of ongoing pain. But knowing how much I used to enjoy the bikes I am Keen to have a go of at least commuting to work. The 90's Raleigh was brought a while back and I did commute a few times on it. What I have noticed is that the brakes do not meet the wheel flat and are at a bit of a angle so there would be room for improvement there. The brake blocks were the spares for the other bike and I wondered if the two types of brakes use slightly different blocks ? I will at first try and tune what I already have and see if I can get an improvement, all the cables could do with replacing. Can anyone point me in the direction on some good info on how to set them up correctly ? If this fails I will go the v brake route. The levers and gear changers are seperate on both bikes.
Do you mean that you used blocks from a bike with Vs to replace the blocks in the bike with cantis? That might explain the blocks not meeting the wheel at the right angle. V blocks and canti blocks have somewhat different mounting fittings.
BADGER.BRAD
Shropshire
When I first had the bike one brake block was missing and another cracked at the one end so to make the thing usable I used the v brake blocks. I cannot at this point until new cables come shorted the straddle wire as the standard cable is too short to allow this, I have highered the bars to suit and this has shortened the cable as the stem is used as a cable stop. I would like to if possible use the original equipment fitted to the bike but if all fails I can swap the brakes from the more modern bike which work extremely well. I have looked at a few vids on Youtube and have learnt something that I never knew but always wondered why and that is the fact that the dished washers/spacers are there to allow for some adjustment to how the blocks meet the wheel ! Just shows in 30+ years of riding bikes I still have something to learn.
Thanks everyone.
  • Like
Reactions: C R
simon.r
Person
Nottingham
Always worth looking at the late great Sheldon Brown’s site for answers to these sort of slightly unusual questions and more often than not a bit of theory to back up his position:
Cantilever (which includes V) brakes explained: https://www.sheldonbrown.com/cantilever-geometry.html
Setting up traditional cantis: https://www.sheldonbrown.com/canti-trad.html
Setting up V brakes: https://www.sheldonbrown.com/canti-direct.html
  • Like
Reactions: C R
BADGER.BRAD
Shropshire
I got some from a local bike shop (blocks that is) I got 10 cables and a couple of straddle cables for less than they were charging for just two brake cables using good old ebay.
  • Like
Reactions: C R
BADGER.BRAD
Shropshire
O.k I fitted the correct brake blocks and shortened the straddle cables ( I had to remove the reflectors) and cleaned up the wheels there was a slight improvement but they were still pretty naff so I decided to go the V brake route using the V brakes and levers from the other bike. I used new inner and outer cables and wow there is such an improvement that I now have another problem, they are that good that with the 90's frame geometry I will have to be really careful that I don't go over the bars ! I also realized I didn't have an end for the inner cables so went the route in the photo !
  • Like
Reactions: C R
