Globalti
Just buy a 5 litre jerrycan of white spirit or paraffin from B&Q and a cheap baking tin or plastic tray and a cheap 1" paintbrush. Clean the chain thoroughly and rinse until the cleaner stays clean. Throw the used cleaner away somewhere it can evaporate or tip it with hot water and dishwash liquid down the sink so the sewage works can deal with it. Dry the chain with an old cloth and leave it overnight before re-lubing with a proper chain lube.
Don't use neat dishwash liquid, it won't remove all the dirt and it will linger in the chain and attack your lubricant as well as attacting moisture. It will also be impossible to get the chain dry without it going rusty.
You can use a chain cleaning device but they're a big faff and cleaner will get spread everywhere including the jockey wheels, washing grit into the bearings. If you clean with the bike canted slightly to the right, cleaner can even creep into the BB bearings ruining them. Best to dismantle the entire transmission and clean, inspect then re-lube everything separately.
