Marie Attoinette Fan
The answers probably no, but can can caliper brakes be fitted to a frame that takes v brakes. The bridge between the seat stays has a bridge between them but the hole is for mud guards and approx 90 deg to what I'd need.
HLaB said:The answers probably no, but can can caliper brakes be fitted to a frame that takes v brakes. The bridge between the seat stays has a bridge between them but the hole is for mud guards and approx 90 deg to what I'd need.
porkypete said:I've a couple of bikes with V-brakes, both have a hole in the bridge that could be used for mounting caliper brakes or mudguards. I'm baffled by the hole at 90 deg? How does the mudguard fit to it? Can we have a pic?
GrumpyGreg said:why would you want to fit poorer (IMO) brakes on any bike?
That could be an idea cheers, they've probably improved a bit, the older ones I've had were worse than my current set up.mickle said:Why not fit cantilevers?
mickle said:You will need hangers mind. What sort of headset are you on? Does the slot in your seat tube face backwards?
Just browsing the net shops and I'd forgotten about them I think I'll have to check out a few lbs. Yip the slot in my seat tube does face backwards although I've rotated the clamp so its slot is to the front as its a carbon seat post.mickle said:You will need hangers mind. What sort of headset are you on? Does the slot in your seat tube face backwards?
HLaB said:I converted the bike to drop/stis last year and caliper brakes are more compatable on my other road bike with the drops to caliper set up they are much better.
The calipers on my other bike are definitely better but that's probably got something to do with the levers Veloce as opposed to Sora and its used in summer conditions and being well set up as you suggest.GrumpyGreg said:I struggle to believe that a well setup caliper is even in the same league as well set up V's even with drop levers. I've currently got drops v's and dia compe v levers and it will stick me over the bars soon as look at me
I've got a set of bar end shifters though, not STI's, for the day when it gets gears again.
Try Avid Shorty canti's stunningly good (for a canti)
