Campagnolo or Shimano
youngoldbloke
May or may not be a factor, but believe Shimano GS rear mech can handle bigger rear sprockets than Campag.
winjim
My right Chorus shifter has just stopped kerchunking after 13 years use. I didn't realise how much I liked the clunk until it stopped doing it! The indexing still works but I have been missing shifts or overshifting without that obvious clunk to guide me.
PS I just found THIS ARTICLE on how to fix the problem!
Oh, and this video on YouTube showing exactly how to do it ...
I have never looked into servicing a Campag Ergopower shifter (I have never needed to until now) but I suppose I will have to while the best bike is mothballed for the winter.
Is @Graeme_FK still active on the forum? I haven't seen him for a while, but he's your man for any Campagnolo servicing and setup issues.
They'll go up to a 29 tooth sprocket, but they do also still make triples for some of their groupsets.
You certainly can buy the Infinito CV in celeste with Ultegra on it. (Mrs A bought one and stripped off all the Shimano stuff to put Campagnolo on it.) And I rode a celeste Oltre at the cycle show last week that was Shimano something or other. Very good it was too.
I have a romantic attachment to Campagnolo from the days when a Campagnolo mech like the Record cost a week's wages for a man (well, for my father at the time anyway) and owning such exotica was a distant dream. On the other hand, the Shimano stuff is light to use, cheaper and easier to live with. Campagnolo needs a lot of careful setting up and cable tension is critical. It lets you know you have changed gear! Once set up and running it never misses a change. Shimano stuff might be thought a little less durable over time, but on the other hand I run a bike from 1979 with original Shimano 600 on it. It has always been faultless.
Conclusion - both are excellent in different ways. It is possible Shimano suffers a bit from making the full range of kit from cheap to expensive, while Campagnolo just makes expensive, very expensive and ludicrously expensive.
mustang1
London, UK
What's to research? A bike is only a couple of tubes joined together with hoops at each end. Those marketing ppl will make you believe there's loads of research and development goes into a bike.
Btw get canpagnolo.
bpsmith
They must have changed their options now then @Apollonius as the main dealer in Gernany told me that when I ordered mine. Was certainly the case when I looked at other models at the time too.
Good to see its changed anyway.
GrumpyGregry
Here for rides.
tbh my personal favourite is SRAMpagnolo
e-rider
Banned member
South West
Campagnolo tools are expensive, and Campagnolo are terrible for supplying spares, however, do you know anyone who got laid for having Shimano components - probably not!
Yes, still here!
Just swamped at the moment with 2016 product training-realted matters and tech support at events ...
