accountantpete
OAP
There's no way a Campag rear mech has been rendered useless after a month or so -certainly not with corrosion - they are built to last a lifetime.
accountantpete said:There's no way a Campag rear mech has been rendered useless after a month or so -certainly not with corrosion - they are built to last a lifetime.
magnatom said:On my recently purchased Ribble I have a Campag Xenon derailleur. The weather has been crap recently, and although I haven't cleaned it as I should I have cleaned it a bit and oiled it. However, lately I've been having problems shifting to higher gears (smaller cogs). It's fine the other way, but will only change up when I hit a bump!
I've checked and oiled the cables, it's not them, and I've done my best to clean and oil the derailleur, but no change. Looking inside I notice that the spring has a hook coming off it. It isn't attached to anything. Is this normal? If it's not this it probably needs a seriously deep clean and lube. I'll just have to survive tomorrow and get it to the lbs on Friday.![]()
MartinC said:Now, now. You're just trying to start a S v. C thread! Comparing Xenon to Ultgegra's a bit unfair. Super Record is far better than Sora.
Coco said:I'm sure I read somewhere that Campags need a bit of running in. Although with your track record, that's unlikely to happen![]()
