It just depends on how much grease there is in the cassette mechanism and that varies a little from wheel to wheel.
Where there is not so much grease (or the grease has begun to break down), you tend to get a louder "click".
Wheels where there is a lot of grease, the grease damps the mechanical noise of the pawls.
Until 2015, the pawl mechanism ran on oil only - Campagnolo recommended that only a very small amount of grease was used in the assembly of wheels with 3 independent pawl springs (which started to phase out of Campagnolo wheel assemblies in 1999 anyway), because grease could "stick" the pawls against the cassette body, slowing engagement down. These wheels have a characteristic, loud, freewheel action.
In 2015 the spring that drives the pawls was increased in gauge and strength and so the factory started to use grease in the drive ring well of the rear hub, as the new spring was more capable of overcoming grease stiction. Typically but not universally, when new, these wheels have a quieter freewheel action.
Grease breakdown can be mechanical (just a result of the repeated shear forces that the material is subject to) or can be caused by ingress of degreasers, detergents and / or other solvents from aggressive cleaning. Generally this area of the bike should be serviced in any case, every 5000km or so - and aggressive cleaning should be avoided.
