Are all Campag freehub bodies interchangable? Can I, for example, take the freehub body off a Mirage or Veloce rear hub and put it on a Shamal or Zonda hub?
Well...it is made a little confusing because the hub designs have changed recently (from 07 onwards)....since you mentioned Shamals then we are talking 2007 onwards and these use an axle shared only by 07+ Record, Eurus,Zonda,Bora etc and can only fit the freehub designed for it.
The Scirroco wheel uses a Mirage grade axle so you can use a 2007Mirage/Veloce/Centaur (all the same part) body on that only.
