Old Geezer
If you have Campagnolo Centaur 10-speed Skeleton Brakes, please help.
The rear brake has a fine adjustment screw on the off-side (I believe this was moved to the top on later/higher spec models). I recently had to remove my rear brake and re-fit it. On trying to fine-tune the centering, I found that the spring arm kept slipping off the adjustment screw. Closer inspection showed that the adjustment screw simply has a ledge, which pushes against the arm of the spring, the spring lodging against it on the bike-frame side of the brake. [I have tried fitting the spring arm on the other side, and it doesn't go.] This seems such an inadequate arrangement that I wonder if I am missing some component. The front brake is different, having a slotted component on the end of the screw that cups around the spring arm.
Please can anyone confirm whether I am missing a part?
Thanks,
J.
Thanks,
J.
