captain nemo1701
Space cadet. Deck 42 Main Engineering.
- Bristol
LOL!.....actually, here are the 'spots'Seems to have developed a leak. There's brown "spots" on the "Enterprise" below it.
Seems a bit on the large size. What's the scale?
Not sure. I have some photos of the surviving miniature used in the movie - it's about 4ft long. I understand that the full size set mockup was about 42 ft long.Seems a bit on the large size. What's the scale?
I will be using some special modelling glue for around the windows, which come in one piece that fits the frame from behind. This special glue is totally transparent when set and is specifically for transparent pieces. I know what you mean though!.Out of all the model kits i made as a kid, I don't think i managed to not get a splodge of glue on one of the windows... good luck!
Revell & Humbrol!!well you've definitely got the correct brand of model finishing supplies
The yellow tape is good stuff but have you only just bought the refills?
IMHO the plastic dispensers are real handy to keep the tape edge clean & straight, otherwise stuck-on fluff makes a mess & dented edges will lift when spraying. Even oil from fingers from handling the naked rolls can hurt adhesiveness.
I get thru miles of the 6mm
That is one of the things I found discouraging at a plastic model exhibition . No droopy wings and collapsed undercarriage or gluey fingerprints on the clear bits .Out of all the model kits i made as a kid, I don't think i managed to not get a splodge of glue on one of the windows... good luck!
