FrankCrank
Old layabout
..........if it was me I'd grab an air gun and put it out of its misery. OK, let it gather dust for a few weeks if you must, but in the end it's the kindest thing to do......
The balsa model used to be covered in tissue paper which had to be shrunk with water and then covered in shrinking dope once it had dried. Larger models could be covered in silk or nylon. Heat shrink plastic film came into use in the late 60's.View attachment 121817 You have taken me back over fifty years.I used to make Airfix kits,my fave was the Spitfire.I also made Balsa Wood kits,with paper which had to be soaked in some liquid,long forgotten what that was.Used to pin the wood out on the drawing paper.Found this on Google.
Dope ....View attachment 121817 You have taken me back over fifty years.I used to make Airfix kits,my fave was the Spitfire.I also made Balsa Wood kits,with paper which had to be soaked in some liquid,long forgotten what that was.Used to pin the wood out on the drawing paper.Found this on Google.
It's actually 1:350 scale, made by Polar Lights (US import, retails for about £90-100 but I got it on ebay for £50). Interestingly, if you had the Enterprise D from ST TNG on the same scale, it would be about 6ft long.Is is 1/72nd scale?
I sat on my Concorde
Ouch!.Are you sure it wasn't Miss Goodbody (or whatever you call her) that sat on your Concorde.
You got a laser then? Doesn't it set fire to the wood?laser cutting
Yohtml
n always revisit the past by purchasing 'stick and tissue' kits from the the Vintage Model Company
Favourites from the Keil Kraft, Veron, Mercury, and Frog ranges are available as replica kits.
I've been busy laser cutting formers and wing ribs for some large - 42" duration rubber powered models.
The airframes look like this 1939 Bullock Streamliner:
I've got my eye on their Caprice.....built and flew one in the 70's
http://www.vintagemodelcompany.com/kk-caprice.html
Shaun
