I'll likely put it back to Beginners - it seemed to work better that way.
What might be a more positive use of this thread (in addition to the OP's suggestion) is a consideration of how best to organise and name the cycling-specific forums.
General Cycling is probably a big part of the problem as it covers, well, everything - so it may well help if it is renamed to Beginners again and then anyone wanting technical help might feel Know How is more appropriate.
Do we need a
general cycling forum if we have all other aspects covered in the more specifically named forums?
Do we have any gaps where new forums would be useful?
What do you think?
Cheers,
Shaun
I raised this last night in Chat after mentioning it on Tundras thread in an effort to give you some feedback.
It's quite tricky because it's basically right. Percieved problems, which I think most agreed on, is that it potentially waters down threads in Know How, Accesories and elsewhere. Nowt wrong with that a few have said. Well, the only negative is that this sub-forum may not quite attract some of the posters who post in specific forums and we know that quite a few people just aim to read some sub-forums and not others. I looked and quite a few people only post in General Cycling, which again is neither a criticism or approval, just an observation. If people are happy in one sub-forum, all well and good.
The other percieved problem is the amount of threads which seem to degenerate into abusive arguments, not discussion but full on arguments. Exactly why, not sure, perhaps because it's less self-policing as it has a different readership, dunno though.
So, how can a change be made to make it the same but better. Well essentially it's a beginners sub-forum is it not, at least everyone thinks it is, so it should reflect that but also reflect that beginners doesn't just mean new but less experienced. So a name change needs to reflect that and disourage it's use as a catch all forum.
No bugger had any decent suggestions
so you're stuck with mine. I came up with Starting Out or Starting Out and Moving On - a forum for expanding your horizons into cycling. Maybe not perfect but you get the gist...
It was also thought, that as it's a forum which new members are likely to hit and new people to cycling as well as the Cycle Chat the modding needed to be subtely different. Namely, quicker intervention on threads which are degenerating and movement of threads which are best answered elsewhere, with a quick note to the OP as to why it's been moved.
So not huge changes but enough to subtely shift the emphasis.
