Caliper Help
rd83
I can't seem to get one my front brake pads square, not sure what to adjust, have had a go but seems to be the same as when I started.
Difficult to see in the picture, but the top edge of the pad hits the rim first, looks like the caliper arm is not square. The opposing arm is fine on this caliper, as is the whole rear caliper.
Anyone know what i need to adjust?
Citius
Looks like it might be upside down. Difficult to tell - if the carrier has a little shark fin on it, it ought to be facing downwards...
Globalti
It's clear from your photo.
The technique is to loosen that hex bolt and by holding the brake lever tight, clamp the brake block firmly against the braking surface while wriggling it slightly to ensure that it is seated flat and the convex/concave washers are correctly seated against each other. Once it is flat and at the correct height to sweep the braking surface and "parallel" with the rim, gently tighten the hex bolt to nip it into place then release the brake and, holding the pad with finger and thumb to resist the torque of the hex key, tighten up the bolt. Check by applying the brake sharply, a well-adjusted brake will make a little "clack" as the pads hit the rim.
If your brakes squeal and need toeing in, repeat the operation but with a twice-folded flap off a cereal packet trapped under the block at its "leading" edge.
Globalti, post: 3964251, member: 357"]It's clear from your photo.
If your brakes squeal and need toeing in, repeat the operation but with a twice-folded flap off a cereal packet trapped under the block at its "leading" edge.[/QUOTE
Shouldn't that be it's trailing edge for toeing in.
