Hi Jimmy
Thank you for your perseverance.....
I wasn't trying to suggest that there is anything wrong with your choice of wheel and tyre, it is just that 45mm is a fat tyre for a "fitness" rider to use.
As I said I bought to bike to use on multiple terrain, I was cycling a pashley which is fine pootelling along the road but rubbish on tow and way to heavy to do Richmond hll.
I was also trying to politely query whether you had the size right
its written on the tier itself which I photographed and brought in doors to check against the roll out test and various online sources, it does seem to be largely comparable. 2260 ish
I'm still not clear what is actually being misread: speed or cadence?
Speed and distance are malfunctioning, cadence is not.
You say the cadence is wrong but also that the RPM is right: cadence and RPM are the same thing, the number of times the crank turns in a minute.
Yes the cadence works and has remained largely comparable.
Your average speed was 13-15mph but is now "30 mps". Assuming that "mps" was a mistake and you meant "mph", then it does sound like the speed is not being accurately recorded. If it is actually 30 kmh, then it may well be accurate and you are just riding faster than you thought: 30 kmh is 18.5 mph.
> yes speed and distance I measure the distance using google distance map and it's vastly out. and my watch is set to metric as is the upload to my computer and the online programme
Check that the two magnets (one on the crank and one one the spokes) are correctly located and within the recommended range of the sensor (on the chainstay).
> yes this has been checked every time I've re-set the cadence unit, you need to reset the magnet on the wheel and the pedal shaft
It is easy to check that your cadence is being measured correctly: just count the number of times you turn the crank in a minute and compare to the Garmin.
> I've no issue with cadence as it seems about right, c.75 rpm
Speed is a little more involved: knowing that the cadence is correct and using
this page you can compare your calculated speed over a measured distance with what the Garmin records.
> as I've said I am pretty sure its a speed distance thing, which MAY be something to do with using circumference not diameter, but why would anyone change it without telling their customers.
Yesterdays ride to Teddington: Very approx for both
Google map distance about 2.8 miles
Garmin watch distance 9.14 mles
Cadence 73 rpm
Speed 28.4 miles per hour
Time taken 19.8 mins
So calculating speed it ought to be c.8.48mph which is probably too slow but at least is more plausible than 30mph (given cycling through Christmas Pedestrians).
Failing that you have a choice: try it on someone else's bike or fit tyres that are in your manual.
Sorry I have no idea what " fit tyres that are in your manual." means. These tires came with the bike as standard.
If none of that works, how much do you want for it?
LOL oh bless you, I suspect I will try and mess with the wheel size and try diameter, also try their customer service, it was an expensive product, NEVER again.
Thanks for your help.
PS just checked on Amazon, its still within warranty, so if it doesn't resolve itself I can at least get a replacement/money back.
