Cables
Philimoreto_8
Regular
Gosport
Got a new road frame with no cables what's the best way to size up the cables both brake and gears. The frames a specialized allez race dsw
raleighnut
:welcome: Buy it by the metre and cut to length, be aware though that brake outer and gear outer are different and avoid 'universal' cable (if you have more than 5 gears and would like to try and index them)
mrandmrspoves
Middle aged bald git.
Narfuk
Then measure the lengths of outer you will need for each run. Brake lever to first cable stop and so on. Keep the outer cable runs as short as you can achieve while avoiding tight bends in the cable - particularly the last piece of outer between the derailleur and last chain stay stop. If in doubt, look at some photographs of new quality bicycles on a website and get an idea of what the cable runs should look like.
Citius
Assuming you are using the same bars and that the frame is the same/similar size as your old one, then your existing cable lengths will not be too far out.
Philimoreto_8
Philimoreto_8
Regular
Gosport
Thanks for the advice
mrandmrspoves
Narfuk
........unless the cable stops are not in similar places, or the cable routing is not the same!
Halfords sell the good old traditional Cyclo ones, I believe. They do the job well. Whatever you use, make sure there are no straggly ends and that the cut is a clean right-angle. It is also worth opening up the hole with the tang of a file, and use the file while you have it there to make sure the cut ends are even. Any unwanted compressions at the cuts will mess up you indexing and shifting, and you will wonder why and fiddle with blameless things like cable tension, H and L screws etc.
