Cable routing front mech
  • Thread starter Deleted member 41544
  • Start date
Any help appreciated here, when re-cabling a front mech after the cable goes through the router on the bottom bracket, where does it go then?
Should it thread through any part of the derailleur or over any part for leverage or does it go straight on to the pinch bolt?
Levo-Lon
If its a top pull then it goes straight in the pinch bolt.
if your cable goes under the BB then it will usually go through the small hole and feed round to the pinch bolt.
hth
put a front mech pic up if your still un sure
migrantwing
Thanks guys, looks like I had it attached right, must be the adjustment not quite right
Loch side.
Also don't forget that the cable can only be anchored in one position under the anchor bolt. You'll see a little groove there. If you mount the cable at the opposite side of the groove, you effectively change the length of the lever and obviously shifting is then all wrong.
thanks everyone, didn't have it quite right on the anchor bolt, live and learn!!
