Cable cutter, will any cutter do?
pclay
Rugby
I use a dremel multi tool these days, cutting disc followed by grinding stone to get a smooth finish. My cheap wire cutters stopped working after about 3 goes.
Profpointy
Having done some googling, I am led to believe that Knipex are also a good make favoured by electricians and the like. I've not had a pair of Knipex ones personally, but since my lovely Lindstrom heave duty cutters are lost, I'm likely to go for a pair of Knipex to replace them - looks like they're around £20 on fleabay for an 8 or 10" piano wire cutters - which sounds a bit cheap to me honest, but worth a go given the reputation.
Re Draper, although people do seem to have better luck these days, I forswore the brand nearly 30 years ago having bought a few things which were simply useless, not merely poor quality - a ratchet which bust first use, a countersink drill which didn't cut, and pozi screwdrivers which simply didn't work at all.
EDIT - after more searching, after all, I'm after a pair myself, I was horrified to discover than Knipex are now part of Draper, so that means either or both parts of my post above are rubbish !
youngoldbloke
I use a pair of pliers, stick the cable twixt the little sharp cutting edges and then whack the plier jaws sharply with a hammer. Beautiful clean cut every time and cost nowt as I had the tools anyway.
I used to do that 'when I were a lad', with my dad's pliers. I still have them 50 years on - complete with the notches in the (blunt) cutting edges :thumbsdown:. Used to cut nails that way too!
I recommend the correct tool for the job
al-fresco
Growing older but not up...
Shropshire
I struggled for years fettling bikes and motorbikes with pliers and crap old cutters, reluctant to fork out money for what was just an occasional job. Then I bought a pair of Fatspanner cutters and, the first time I used them, I wished I'd bought them years ago. If it's a job you do more often you might want a better quality pair but these will do for me.
Ajax Bay
East Devon
Resurrecting this thread to seek advice.
I 've got a pair of Draper Expert cutters that cost about £10
I, too, use these Draper Expert wire-rope-or-spring-wire-cutter and they do the business. Still <£10.
But having broken an FD cable last weekend I am looking at the issue of whether one, on a long ride that it's important (to you) to finish, whether carrying a spare gear cable (and a brake cable) is prudent and worth the weight. I used to carry a cable but it dropped below the threshlod of items to carry. But that also begs the question: what about cable cutters. If you're lucky the parted cable can be removed from the outer by just pulling, even if it has frayed at the end, and last weekend I was able to do this (and use the lower limit screw to push the chain onto the middle chainring). It was Saturday so 50km further on I was able to buy a cable and fit it. But I would not have been so lucky later in the day or on the Sunday (maybe).
I could not countenance carrying the cable cutters linked above: they are too heavy and too bulky.
Does anyone have recommendations for effective but lightweight and as small as possible cable cutters you could carry (I'm not talking panniers here)?
Bodhbh
Park tool cutter sounds like a good one for that price.
I've got a pair, and they still cut cleanly 9yrs down the line. They get a fair amount of use, and I tend to use Goodridge outers (tough as old boots). You still need to give the ends a quick file to make sure they're flush tho.
